Home/ Preguntas/Q 23270
Pillsplace
Pillsplace
Asked: junio 28, 20252025-06-28T20:01:17+00:00 2025-06-28T20:01:17+00:00En: Producción
How Cenforce 200 Works?
Cenforce 200 contains 200 mg of Sildenafil Citrate, the same active ingredient found in Viagra. It is classified as a PDE5 inhibitor, a type of drug that helps treat erectile dysfunction (ED) by increasing blood flow to the penis.
Step-by-Step: How It Works in the Body
  1. Sexual Stimulation Triggers a Response
    Cenforce 200 doesn’t cause an erection on its own — it requires sexual arousal to be effective. When a man is sexually stimulated, the body releases nitric oxide (NO) in the penile tissue.
  2. Nitric Oxide Activates cGMP
    Nitric oxide stimulates the production of cyclic guanosine monophosphate (cGMP), a chemical messenger that relaxes the smooth muscles in the walls of the blood vessels in the penis.
  3. Blood Flow Increases
    As these muscles relax, blood vessels widen, allowing more blood to flow into the spongy tissues of the penis. This increased blood flow leads to an erection.
  4. Sildenafil Blocks PDE5
    In men with ED, an enzyme called phosphodiesterase type 5 (PDE5) breaks down cGMP too quickly, which prevents proper blood flow and makes it difficult to achieve or maintain an erection.
    Cenforce 200 blocks PDE5, allowing cGMP to remain active longer. This helps maintain the relaxed state of the blood vessels and supports a firm erection during sexual activity.
  5. Erection Subsides Naturally
    After ejaculation or when sexual stimulation ends, cGMP levels drop naturally, and the erection subsides.
Why the 200 mg Dose?
Cenforce 200 is a high-strength dose, intended for men who have not had sufficient results with lower doses like 50 mg or 100 mg. It provides a stronger and more sustained effect but should only be used under medical supervision due to its potency.
0
  • 0 0 Respuestas
  • 20 Vistas
    • Usuarios : 5k
      EXPOSE ROBOT HIJOS
      javascript no ejecuta en robot padre
      • Respuestas: 2
      Abrir nueva pestaña por xpath
      • Respuestas: 2
      "Send keys to web" no responde
      • Respuestas: 2
      Error al abrir transacción en SAP
